The only conventional CVT rav4 has is the K120 transmission, with these models using it
no one worried about hybrid wire corrosion (this thread) has one of those K120 transmissions
(unless they also have an XA50)
we all have directly meshed metal gears and planetary gearset. no slipping belts, no kevlar belts, none of that
K120 "Direct Shift" transmission (2018)
Toyota brands the K120 as the “Direct Shift” CVT and includes a physical first gear (also known as a "launch gear") and nine additional simulated gears, for a total of 10. The launch gear is engaged when the vehicle takes off from being stopped and transitions to the belt drive as the vehicle picks up speed. The benefit of this system is that traditional CVTs tend to have low efficiency in lower gear ratios, creating a moment of sluggishness when starting from a stop.
[2] Since the belts in this CVT are handling a narrower band of ratios, belt angles and loads can be reduced, increasing shift speeds and offering a claimed 6% improvement in fuel efficiency.
[3] Production began in October 2018.
Applications:
the CVT pushbelt for the K120 sure looks like an ordinary metal CVT belt, not kevlar
this>>"Rav4 uses a cvt transmission too just the belt is a braided Kevlar material so it's supposed to have twice the life expectancy of a normal cvt transmission, also Toyota builds these cvt transmissions significantly better internally over their competitors "
I am gonna say no. the reason the CVT last longer in the K120 is the normal first gear (launch gear), that takes a lot of load and heat off the CVT
so that the CVT belt is only in use when already moving, greatly increasing lifetime and reducing heat and wear from standing starts.
