Is any one else's middle connector boot near the air box split like this? I can only assume it shouldn't be.
Stick your finger in that gap and wiggle it around. >:D
Its completely normal, that is just a shield that wraps around the harness. Mine doesn't have that gap but its open and I can spread it apart by wiggling the harness.
Good to know. They look like they're supposed to be molded together so I assumed it split. May mention it at the dealer next time I'm there. Which shouldn't be for a long time with 16,000 km oil change intervals.
I figure it's not all bad. You can stick your tongue in there to see if the battery is charged like you do a 9v battery. >:D
Disclaimer: no one should ever stick anything, tongues, fingers, tools or otherwise in there for risk of death. Darwin would be at work and that's not a bad thing, but I don't want to be personally responsible.
