1 - 14 of 14 Posts
This time, I have found a bunch of leaves and debris under the driver's side hood hinge. I can barely reach in to get them out...and thinking I may not want to with all of the strange creatures we have here on south Florida. Wondering if anyone else has noticed this...I find it odd.
That's weird. Can you wash it out with the garden hose?
Yes, very odd...and having owned many cars that collected debris like this, realize it contributes to future rusting issues. I don't think there's any place for it to go, so think hosing it out is out of the question. Just wondering if anyone else has this issue...
I have had it here in northern Iowa all the time! It doesn't work that well to hose it out usually. I have found it easiest to try and use an air compressor instead. If that doesn't work, I cleared mine out really well when I run new wires through the firewall. (You have to take off the wipers, wiper motor, cowl, etc but you get really easy access to all of it)
Most of what you can't reach with a gloved hand you could get with a pair of long hemostats or even two sticks used like chopsticks. Then blow the rest out with compressed air or a leaf blower. But keep the processes dry since water might only force some of it farther in.
Common on every car I've ever owned that got parked outside under a tree.
Mine too. But w/o cavities for it to drop into a few seconds with the leaf blower takes care of it.
We sometimes have that problem with both fir needles and leaves. I've used a vacuum cleaner, avoids getting debris all over and in the engine compartment.
I am the queen of strange questions...
Don't worry about the odd questions! Chances are if you have it, someone else either has the same question, will run into the same question/problem, or has seen it and knows how to solve/answer it! I appreciate all the random/strange questions and have even asked a few myself! We all get to learn something new!
Yep, that's probably the best answer for the OP - a shop vac with a long thin nozzle attachment.
Discussion Starter · #13 ·
Yup, thanks for the shop vac idea! I hadn't even thought about that. Gonna give it a good once over today or over the weekend. Good thing is that even if it rains, it won't matter with a wet/dry vac.
1 - 14 of 14 Posts
