G
·I had enough of that buzzer. It is now dead. Here is how
Pull bezel off of cluster. Pull straight off
Tilt the steering wheel down and telescope it out
Unscrew the two screws holding the cluster in
Pull the cluster straight out and lay it down on steering coloumn
Undo connector from back
Remove cluster from car. Seperate the back from the cluster by gently lifting the tabs. Pull apart.
Remove cover from buzzer pry gently up
Remove gold disc and snap on cover
Install black cap (snap back on ) without the gold disc. The gold disc is the Piezo buzzer which is making the noise for the seat belt and door being open.
Install cluster in reverse order as taking apart. The only thing not working with the seat belt buzzer is the door open chime. I can live without that
