281 - 286 of 286 Posts
Isn't 84040-33170 same as 84040-06070 except newer
Same. I ordered 33170, the packing list invoice said it’s 33170 but the part was 06070.
I thought about this some more after I had posted it last night. One thing that bothered me(still does) is what is that GREEN wire in Pin2 of the wire harness,
The Rav4 detects when windows and roof are open (I don't think so on corolla and CH-R).
May be this green wire is used as signal when windows is closed...
For the wiring of the front passenger window and lock switch to be illuminated, how about tapping into the LED light in the passenger shelf area? I imagine running something off of that and into the door shouldn't be too hard? Idk as I'm not good with wiring but just an idea
could be. i m a complete newbie in this - so hoping someone would do the initial wiring stuff and then guide me how they did it. For rear seats, the only thing I could think of was either splice/solder or use a t-tap connector to connect to and tap the original wiring - however I am very hesitant with tampering with OEM wiring - so wondering if someone could provide alternate solutions.
Discussion Starter #285
Looks like you guys are running parallel to the same process I've been going through. I didn't have the wiring diagram, but I physically pulled an illuminated switch apart (thanks @ksingh0311 ) and identified the LED pins as well. I was also thinking of pulling the voltage from the rear heated seat buttons using vampire taps, but I hadn't gotten that far as I was waiting for the weather to warm up and I've been busy with other stuff. Additionally, I'm not sure how to go about adding a terminal into the wiring harness; maybe it's not difficult but I don't know.
