2020 RAV4 hybrid XLE, Magnetic Grey metallic, cold weather package.
You can also look for part 84040-33170So I’m trying to digest all these posts, to summarize it looks like Toyota part number 84040-06070 is a OEM Camry part that is plug and play for our RAV4s. If I understand that right, that’s what I’d like to go with.
Also, can somebody point me to a video or post that shows the install?
Thanks much.
Which fits 2019 ch-r. It is the same part just older part number.
As for video, just Google " replace [year] rav4 master switch"
There is a bunch of them.
The only thing important is that you start prying the pannel from the near edge, one on the left when facing the door from inside. That is where the snap hooks are. The edge closer to mirror control switch has a J hook and will break if you start there. !! This is for Master switch only !! I would guess it the same for passenger sides too but check for that separately.
Here one for Master
And here for both sides:
However, if I understand correctly , while the driver side Master switch if a direct swap, for passenger doors you need some kind of adaptor to add power to lights.
