1 - 14 of 14 Posts
ok here is my new toy this is what it looks like when is close
here is it open
1 problem I have is the opening at the bottom any suggestions on how to fix it.
P
AV indash
Ive got... the pioneer AVIC 1 r in my dash...
I am glad with the results.... even my little girl
can watch it from the backseat with ease....
I still wanna upgrade with 1 extra screen on
the sealing... between the front seats...
new toy
here is it open
If you check with an installation store, (best buy, circuit city) they may have the kit with the holder that goes in there and makes it usable space.
Could remove the plastic panel and patch the opening from the inside with another piece of plastic and then you have to fill the exterior depression with coumpound and sand to make it even. Finally, cover with carbon fibre type cover-up or wood grain or stainless the choice is yours. Maybe if your sanding and finishing touches are good then you could just spray paint it the color of your choice.
If you want it to be useable space then you'll have to get a box to put inside but the finishing touches will require some further work like above.
Can be done. Later. M.
Discussion Starter #7
got it
Thanks Alot got it . I will post picture of after market holder less than 20 dollars
Discussion Starter #11
what r u talking about
Marcutio said:
I want one. Where is the best place to get one? Is it hard to install?
M.
are you taliking about the tv or the aftermarket pocket din
1 - 14 of 14 Posts
