1 - 20 of 105 Posts
G
Amps are in. Sub is out. still need to run speaker wire. work up a way to mount the sub and make the grill look pretty. not much room for the sub as you can see.
amps in just needing the speaker wire put in.
sub out
comparison w/ a mb quart 8"
hopefully to get done next. mount sub. run all speaker wire.
then next session will be the speakers and the head unit, followed by steering wheel controls.
thanks for your time.
The mb looks much deeper then the oem sub. I too will be anxious to know how it fits.
G
sub is in. took about 1.75" of mdf to build it out. also had to trim some of the back panel to go around the speaker. Here it is.
TO build out the speaker grill I went to Home Depot and found a 12" black abs planter.
G
Got the rear speakers swapped. what a PITA. Had to drill new holes to hold the brackets, then add the speakers. taking the doors off was easy. Running the speaker wire through the wire connector mounted to the body of the car was evil!
ANyways, these actually look like decent speakers. still paper though. nice sized magnets.
I'll be keeping up with this thread. I've got a limited without the JBL upgrade. Wasn't available when I was looking for a Rav. I'd like to add a sub or two in my vehicle so I'm gonna have it checked out at the local car audio shop. I'm thinking that the hole for the Sub is in the back door under my door panel even though I don't have it. I'll guess I'll find out soon...
Pretty nice set up i recommend fiber glassing the rest to look stock let me know if you need any help.
i would also built a wall with flexiglass that way you amps are prcotected and it will look professional.
G
Discussion Starter · #11 ·
Well, the Front speakers are in. the headunit is in. I used the Pac SWI-alp and I actually got the steering wheel controls to work. A little sketchy and delayed but they work allright. Side note, the jbl shares nothing with teh regular 6 disk changer in way of wiring harnessl. I got the harness from crutchfield in hopes that I could use some of it to at least get power. hmmm, nope. had to splice the whole thing. that took sometime with the steering wheel controls. Nice about the jbls is the front tweets are like an 1.25 or 1.5 set. and the front cones are poly with rubber surrounds. the rear doors had like .5 inch tweeter and a paper cone. didn't match....
SO all the mb quarts are in and the stereo works. sounds 100x better.
Things to do...
get a 1 din pocket from toyota, the scosche one looks cheap.
have to cover the sub still
I want to make a pretty cover for the amps and seperate them a bit. probably use mdf and carpet because lexan would show off and my goal here has been to hide this stuff to look stock except for the HU.
Anways here are some more pics.
G
Discussion Starter · #12 ·
Looking really good so far. I'm dying to swap out the stock radio on my '06. Can I ask where you got the dash kit from and how much it cost?
G
Discussion Starter · #13 ·
nice stuff... i wish you'd find something to fill that hole in your dash... looks a bit empty to me... keep it coming though.
G
Discussion Starter · #14 ·
There was a classified post awhile back and a gent from japan sold me an oem one for 70 shipped. To me the oem was worth it.
I feel the same about the pocket. I wanted a dvd player but decided I wouldn't use it. I don't watch movies in my car just drive and listen to radio. I ordered an oem pocket from a camry. I will see how that looks and I am trying to shape the trim piece from the alpine to fit and see if that looks better.
I am also considering some LED's and a piece of white teflon. I can hook it up to the led kit already and switch it on with that or just have it on with the radio. make some nice mood lighting. Probably going to take a break for awhile with mothers day coming up. but will post more when I get the cover for the sub done.
G
Discussion Starter · #15 ·
Anybody know where to order an OEM kit from Japan from?
G
Discussion Starter · #16 ·
Well my mb quart 8 inch sub just blew. anyone interested in trading rear door panels? I would include my jbl sub with the door. the grill is in the process of being glued back on. I want a black rear door panel.....no sub hole.
G
Discussion Starter · #19 ·
I am assuming the same thing on the free air. I did try to seal the area but couldn't really fit a box in there. Worked fine at low volume but the first time I turned it up one of the coils went. might look into fiberglassing a 10 in place and building a nice box on the door. might be too heavy for the hinge though?? Any thoughts?
1 - 20 of 105 Posts
