Hi went to home depot today to look for plastic gutter gaurd for lower condensor protection as others have done, thanks for heads up all! only had white in plastic so went to Lowes, same thing so I bought the black metal guard,
Installed on the outside of factory plastic as was to lazy and hot today, cut a little strip off end for template on height,, did not cut width as it was perfect,and cut out,, then tie wrapped in place, I did use painters tape for lower paint protection as some ends are sharp,,
After cutting there is enough left over for 2 in case you know someone that needs also.
