If you have the tow prep package (140A main fuse) there's an open-ended white wire behind the lower left to the dash. I didn't know that when I installed a trailer brake controller so I tapped into the heavy white cable in the linked picture.
Hey, If you are only installing a remote starter to a vehicle with PTs (Push to Start), you usually do not need very high current. All starting procedure will be handle by the vehicle ECM. Since all remote start will still need to have access to the CANL and CANH line which can be easily access at the DLC (ODB) connector, there is also a constant 12V supply line at the location that you can tap into. That is how I install ( recommended by a name brand manufacturer) one in my other vehicle which is a PTS camry Hybrid.
