1 - 9 of 9 Posts
Hi, I have just picked up an Excel AWD Hybrid, 7 months old, 1300mls. Interior lights do not work when doors are open.Front/back turn on manually, tried overhead door switches, no luck. Any help please?
Did you try reading the manual? English verison is available online. If you need King James version, that might be tricky. Thou shall read the manual to find thy anwers.
Owner's manuals are available online in the UK too. (y)
2919 Rav4 Hybrid Limited, Entune 3.0, Adaptive Headlights, Advanced Technology Package built June 20
There is a UK Rav4 owners club forum at Rav 4 Club that may help as we don't have an Exel in the US.
The UK Exel is comparable to the the North American Limited trim.
Comparable does not mean the same software. I've seen enough cases where location matters to cause me to see if a local source has a better answer for the OP than me assuming the two cars are the same.
I hardly believe that something like the interior lights have anything to do with the softwareversion...
Discussion Starter #9
Hi all, thank you for your replies. As this is my 1st rav4 I'm unfamiliar and should have looked at settings. With being an on/ off switch on consol I did not assume it could also be turned on /off with the software. Problem sorted.
1 - 9 of 9 Posts
