G
Major aggrivation,internal drivers door handle has lost its connection somehow to the door latch,this is embarrasing as I've told everyone how good Rav's are!,is this a common problem/easily fixed?
I repaired the outside handle on one of my RAV4s, and replaced the front speakers in both, but it has been a while. If I am remembering correctly, there are a couple of rods that go between the inside handle, outside handle, and the lock. My guess would be that your handle has broken on the inside where the rod connects to it. See if you can remove the inside handle alone, but you might have to pull the whole door panel as the rod probably swung down. There's lots of sharp sheet metal edges in the door, so be careful! And it helps to be a contorsionist ...
