Had a number of troubleshooting conversations with Toyota Canada and my dealership about the non-functional connected services. TLDR: still no solution in sight.
Toyota Canada
Toyota Canada
- Talked to their customer support, walked through similar troubleshooting steps as above:
- Does it have a green light next to the SOS button when started
- Yes, solid green
- Does the App work? Do you get an error when trying to use it?
- No, the App just times out whenever using it, no error message is produced
- They did specifically asked if I got an 'error 42'
- Does the Key fob remote start work?
- No, hasn't worked for a similar period of time
- They indicated that there was no resolution available at this time
- There seemed it be little other information available to customer support on what was going on or causing this
- Asked that I reach out to my dealership to have them connect it to their computer for diagnosis
- Had a worksheet from a Connected Services person to work through (most of the questions were similar to Toyota Canada customer support):
- Does the Key Fob or App remote start work?
- No to both
- What is the status of the DCM (SOS) when vehicle is running?
- Solid green light
- What happens when you try and start the vehicle with the App?
- The 'Start' button spins for 2 minutes and then stops with no message
- What happens when you try and lock the vehicle with the App?
- The 'lock' button spins for 2 minutes and then stops with no message
- Based on those responses, the Connected Services person was going to investigate behind the scenes on what is causing it to not work.
