2006 Rav4 Sport 2.4L 2WD Original U241E transmission suddenly dies within hours last Friday. Car has 207,000 miles.
Car wouldn't even move and sounded like thousands of rocks in there.
Had a certified used U140F transmission shipped in from MD and local mechanic did the transmission
swap. Picked up car today. Biggest problem is car won't go into Drive (D) after 3rd gear.
Will auto shift itself from 1st, to 2nd to 3rd but that's where it ends.
I know the mechanic had to swap out the end plate from the old tranny to the new to fit in the engine compartment but not sure if any sensors or anything else needed to be swapped from bad transmission to the newer replacement.
Does the ECM or ECU need to be reprogrammed or reset so the car can go into DRIVE? IS that the issue or something else?
Thanks in advance for any advice!
