Does our 2019 Rav4 have other Jacking Points other than the typical ones that are on the sides (notches) ??? I see two more but I just want to make 100% sure ! Thanks guys.
See page 564 in the owner's manual, there are pics of the front and rear floor jack points.Does our 2019 Rav4 have other Jacking Points other than the typical ones that are on the sides (notches) ??? I see two more but I just want to make 100% sure ! Thanks guys.
https://www.toyota.com/t3Portal/document/om-s/OM0R009U/pdf/OM0R009U.pdf
I am in general agreement - however being only a shade tree mechanicaI am at a bit of a loss on where to place the jack stands once its in the air other than under the pinch welds. Under the Control arms I suppose - but that doesn't look that solid, and putting stands under a sprung position can cause things to shift if the car moves?I have learned this over my years as a mechanic. Don't EVER lift a car by the pinch weld. As soon as you do, you crack the paint/sealer and it starts to rust. I always lift by a solid structural member. Ask me why I have to replace the rocker panels on an otherwise perfectly healthy rav4 that I bought from a friend.
I like to use the sub frame or a plated joint.
Please....on the '19, not on the 3rd gen.Can you show us some pictures for the benefit of others, please.
