1 - 2 of 2 Posts
I just bought a 2006 base model. Contacted Toyota for the complete build list. This car came with only 1 standard aftermarket metal key. The build list says keyless entry. What keys do I need?
Thanks in advance,
Steve
Thanks in advance,
Steve
something to consider...in another post you said the glove box was stuck...most likely locked tho...did you try to unlock it with your ignition key and did it work?...if you tried to unlock it with the ignition key and it did not work then your key may not be a master key...you can buy remote keys off ebay and amazon pretty cheap, but in order to have a master key cut you may have to have a dealer do that...something to keep in mind...
Toyota RAV4 Replacement Remote Head Key Fob Keyless Entry Remote Transmitter | eBay
1 - 2 of 2 Posts
