I just installed an oil filter from my 99 4runner. It fits and its just a little bigger than the recommender filter for the 2000 Rav4. It fits the threaded shaft and seats on the flange just fine. It has about a 0.15" bigger radius.
Is there any reason I should not do this? Check the specs in the attached pics.
14476 Rav4
10241 4Runner
I have run a larger oil filter on my 07 4 cylinder Tacoma for years with no noticeable ill effects. I use the Denso filter designed for the older 6 cylinders. It is the same one my son's 1998 4Runner uses. So, I order them by the case to use on both vehicles.
