1 - 11 of 11 Posts
I'm having problem installing LED Dome light. anyone have any suggestion please help me. Thank You in advanced. I try so many LED Dome light but i can't get it to fit in.
You can VERY gently bend the bracket which holds the bulb, or try to look for 30mm bulbs. I have a 31mm in mine right now, but it took some massaging to get it to work.
Sent from my SM-G930V using Tapatalk
i bought the feestoon 31mm
It's SOB to fit bulb in. Must be the dumbest. If it was a "push fit" instead of "end fit" as installed would've been easier. Upside down, small bulb, no room to hold bulb with fingers and still see the small hole the bulb fits in. Forcing bulb in pushes the movable contact too far to spring back for a good fit. ugh!:mad:
I had to dismount the whole base, turn it over to install. It's quite easy.
BTW, your 31mm festoon may be to long to fit. 29 or 30 mm will fit easier.
I got 28mm, fits nice and easy.
My roof light not like that. Lens is separate, bulb is in holder.
mine too just showing you the pic of the led bulb I have on mine it is a 28mm, hope this help to clarify.
Thats what mine looks like. Where did you get your LEDs? I got mine from superbrightleds dot com.
1 - 11 of 11 Posts
