Hello all I wanted to change the reverse light into LED but the bulb was loose and it got stuck inside the housing. How do i get it out?? Its a 2016 Rav4 Hybrid. Thanks.
Since the socket plugs into the bottom of the housing I would think the bulb would be close to socket hole. Did you try to just reach in with a few fingers? Worst case drive on a bumpy road :)
Sent from my R1 PLUS using Tapatalk
Happened to me on a 10 th Gen Corolla. Good thing is the Corolla's reverse is on the trunk lid so I can stand up straight and fish it out using a tweezer. I have the same RAV4 as you. Only way to get the bulb out is to remove the whole lamp and use the tweezer. Good luck.
