Let’s start off by saying the RAV4 fought me the whole way. Partly my fault and partly rusted parts on the car despite being a 2014. I initially installed a ready lift kit. The hardware was not the right thread and could not bolt it in to the subframe. So I contacted the company. Ready lift is a great company and has amazing customer service. I would have kept the lift kit however the kit was not designed correctly. The front spacer did not have a good offset. And rear kit did not feel safe. (See picture). I spent a lot of time installing it. The process was not to tough. However the rear headwear did not match up with factory bolt thread pattern (see picture). Anyways I removed the ready lift kit and set it back. After much research I decided on the Eibach lift kit. This kit is much better in my opinion. It uses springs that are stronger and stiffer to achieve a lift also so far the ride seems more smooth and stable around corners. See picture.
