Is there a listing of the audible beep codes for the rear lift gate?
My lift gate intermittently:
Starts to open then halts
Opens fully and emits a single long beep
Opens fully and emits two short beeps (maybe this is the ’normal’ state?)
Starts to close then halts
Whenever it acts up I’m able to open/close it by hand - a little stiff but it always works. And never fails to latch the via the electric actuator once the door is manually closed. And after driving for 15 minutes after a fault it’s unlikely to repeat the issue.
I think it’s trying to tell me what it thinks the problem is but I don’t speak its language! I’ve done a bunch of web searching, but haven't found a list of the beep diagnostic codes.
It’s been having trouble for a few months - seems to be worse in colder weather? I thought it might be sensing something pressing on the pinch-detector strips, so I’ve carefully cleaned those as well as all of the areas around the hinges and latch, but no luck so far.
TIA.
2019 RAV4 Hybrid XSE
TIA.
