1 - 8 of 8 Posts
S
:shock: Can someone please help me?
My light on the shifter is gone out. Anyone know how to replace the bulb on a automatic 97 rav.
thanks.
N
Discussion Starter #2
You have to remove the whole center console with the two screws at the base of the armrest. Then the screws on the side of the console 4 total. Lift up and back the whole center brake console. The light (W5W) is on the drivers side under the shifter and it twists out.
R
I'm trying this and I've twisted the bulb holder out, which is still connected to the wires. How does the actual bulb come out, mine's stuck! Sorry if i'm being thick...
D
Discussion Starter #7
hi i done mine about 2 years ago. the bulb should just slide out it should be kinda flat on the end and just slide into the holder.its hard to describe
R
Discussion Starter #8
thanks i'll try that. if it's supposed to come out easily I guess mine is stuck pretty bad! I guess the last resort will be to smash it and pull the remaining stuck bit out with pliers...
1 - 8 of 8 Posts
