I did a quick search but not sure if anyone here has replaced there tail lights and brake light bulbs with LED. If so what brand bulbs did you buy?
Two weeks ago I installed Philips 7443 Red Vision LEDS bulbs which I got at Pep Boys.
They fire the light back toward the reflector, so the whole lense fills with light that equals the original incandescent bulbs. They are CK socket compatible, so they wont blow any fuses like other LEDs can.You may have to rotate them in the socket if the brake lights don't work.
For around $25, I am very happy with them. I also used the Philips 921 LED backup bulbs for around the same price. I did not touch the turn signals, because I did not want to mess wih those load resistors. I also did not touch the inboard tail lights because they don't have to flash on instantly like the brake lights have to and they look fine next to the LEDs.
Thanks for the info, I will be changing all of mine out shortly.
