1 - 13 of 13 Posts
Can anyone with a limited hybrid compare the indoor roof. like I would like to know how thick is the difference between XLE indoor roof vs Hybrid
Would like to help, but what do you mean by indoor roof?
Thickness of the insulation?
Distance from the floor?
You want a pic of what exactly?
Pic of the material they use for the indoor insulation. Like where it should be soft touch for cars
I meant the upholstery
The XLE and Limited have the same material for the headliner. It's a gray hard cloth textured material. It's probably the same in all gen 4 RAV4s. Easiest thing is to stop by the Toyota dealer and look. Or go on cars.com and see some shots of on pictures of the moonroof from the inside.
The limited hybrid seems to be the same hard fabric covered material that was in my 14 xle.
You are not paying for the Lexus NXT. You are not going to get a nicely padded headliner.
I've never had a problem with the headliner. It's not something that get touched or wear a lot anyway. I remember back in the day when headliners would droop and you would have to get it glued back on. I don't think that is a problem nowadays. When is the last time you had to repair your headliner from wear?
Hey, I owned a Dodge that had a plush velour type headliner. Very nice. But after owning it for 5 years, the backing deteriorated and the headliner starting falling down on our heads. Had to stick it back up with thumbtacks. I'll take Toyota's cheap headliner any day.
I assume you're considering getting one of the models yourself? Why wouldn't you just visit a dealer to see the real deal?
1 - 13 of 13 Posts
