Obviously the best way to find out is to try it. Just make certain that you have an extra key or whatever is needed to re-enter your vehicle if you have to leave a key in the ignition for the engine running experiment.
Reactions: RTexasF
I have push-to-start button. I can start the engine, lock doors and walk away with FOB in my pockst. It will beep at me, but it stays running.
Also, I can remote-start it with locked doors.
Can I lock the doors with the motor running?
This is the only way I can do it. Start engine. Lower driver's window fully. Exit the vehicle. Reach in and lock the doors with the power lock button. Pull up on the driver's window switch and quickly remove your arm. And pray you have another key available to unlock the door.
2010 Toyota RAV4 Base I4 4WD 2.4L L4 DOHC 16V
I had a third party remote starter installed (Compustar Pro G15). Works like a charm.
