Just went outside to turn my RAV on so i could go to work but when i turned the key in the ignition to crank the engine all i heard was a loud click and then nothing. Ran the multimeter across the battery terminals and it reads just over 6V. The battery was only replaced in July last year.
None of the electrics work apart from the flashing led on the dash (for the immobilizer). With every flash i can hear a loud click from under the dash. I'm thinking it's a relay noise? The flashing led and clicking noise stop when i depress the brake pedal or open a door otherwise they keep flashing and clicking.
Gonna try and jump the RAV with my sister's Echo but if that doesnt work what do you guys think it might be? I'm hoping it's just a faulty battery which should be replaced under warranty as it's less than a year old.
