My passengers side low beam bulb stopped working on my 2013 Rav4 just the other day. I replaced the bulb and the new bulb didn't come on. I switched the new bulb with the driver side bulb and the new bulb functioned just fine (not surprisingly, the old drivers side bulb did not work in the passengers side).
I checked the wiring on the passengers side low beam bulb jacket and it looks fine.
Is there a passengers side-specific fuse or something that could have blown out?
Thanks
Question: Do both DRL's come on when the headlights are out? The high beams are used as daytime running lights wired in series so they get reduced voltage. There are several relays and/or fuses you can check in both fuse boxes under the hood.
Rick, you sir, are a God! Thanks so much for the fuse diagram and notes.
Yes...both of my daytime running lights are still on even on the side of the light that is out.
I will check the fuses as soon as I can and hopefully I'll find the culprit.
