2005 Toyota Rav4
2.4 L
Automatic
182k miles
Bought the car at 55k miles. Used to get great fuel economy, but it's been poor for several years. Last two tanks have been 20 and 21mpg. Mixed city highway driving.
I've been playing with a simply OBD II scanner. Here's what I understand.
The long term fuel trims are high indicating a lean condition
Notable maintenance:
I have data at Idle and 2500 RPM, and a Wide open throttle road test below
WOT: 2005 Rav4 OBII scanner WOT
Any ideas what I should be testing to trying next?
IDLE
IDLE O2B1S1 and S2 (V) Graphs:
2500 RPM
2500 RPM O2B1S1 and S2 (v) Graphs
2.4 L
Automatic
182k miles
- New denso plugs and coils around 160k miles
- Cleaned MAF sensor and Throttle body last week, though I did not remove the TB for a proper cleaning, but I did at 150k miles. Not sure if I've ever cleaned IACV properly.
- Ran Seafoam in gas tank two tanks ago
- Very regular oil changes, burns no oil
- Original Cats
- I've seen Long term fuel trims as high at 25% while cruising at 40 MPH, but is usually around 15%. Short Term always seems pretty low.
- I noticed that under WOT the Throttle position only read 80% open and load only at like 66%. I was going about 15mpg when and then floored it.
- Poor fuel economy
- Also, I still occasionally encounter the low speed surge in stop and go traffic.
- Very smooth idle otherwise
- No check engine lights or codes
IDLE
2500 RPM
