1999 Toyota RAV4 with 3MZ-FE 6 cylinder engine, camo wrap, OME lift, heavily modded
Hey Mensajero, what transaxle does the Celica ST162 use, looks like an S53 or S54 (basically the same other than gear ratios I believe). You would have to research the parts breakdown between the E250 transaxle and whichever of these the parts were for and see how the part numbers compare for a start. From an initial look it doesn't look too promising.
Good luck, let me know what you find, it would be nice to have a front locking transaxle if it were compatible with the E250F.
I'm really glad you came out okay, I hear Vieques is pretty bad.
There is no LSD that can fit in the 4WD transmission. You can only put one in a 2WD. The reason is that the 4WD is 2 diff inside one.
Reactions: eodgator
