1 - 13 of 13 Posts
First post, greetings all! I own a 2016 RAV4 and I run a dashcam. It is plugged in the accessory outlet up front but I want it to be powered constantly, not cycle on and off with the key. At first I thought there must be a way to do this at the fuse box under the dash, you know, jump a powered circuit to the unpowered outlet circuit but I could not get it to work for the life of me. I don't know if I'm missing some detail or if I'm just stupid. Any ideas??? I REALLY need to power my dashcam constantly. Thanks in advance and it's great to be here!
Try this product. I also have this for my dashcam and it works great. Here's the link to Amazon It's called Power Magic Pro, and they also have a shut off feature incase the power drops too much on your battery which can prevent your car from starting in the morning. It's really easy to install it.
Thanks for the link. I didn't buy that exact item but I did see a $9.95 wiring kit that I'm just going to run to something that is constantly 12v under the dash. I'm not worried about discharging the battery as it is a minuscule power draw.
I have not seen a wiring diagram for the Rav4 but in my 2007 Caravan one could replace the power relay that fed the lighter socket with a dummy relay with a closed contact all the time to supply power. If there is a specific relay that feeds the lighter socket only, one could then take the relay out and block the normally open contact closed. Maybe Toyota has an optional replacement relay with a always closed contact to solve this.
Frank 2015 Rav4 XLE AWD with 18300 miles
That's genius! My previous vehicle was an Xterra and wow there was a boat-load of online information on that. I'm surprised there aren't manuals available online for the RAV4.
See the sticky in 4.4 Interior Every wire and its location.
Discussion Starter · #9 ·
I like your bug deflector, I see that Autozone has one for $40, any insights into that particular brand or other general insight regarding bug/hood deflectors?
Have you found a solution to your problem, and if you have let me know as I too would like constant power to some or all power adapters... Thanks
Discussion Starter · #11 ·
I think the solution is to run a hot wire from the battery, fused, to under the dash and use it for what you need. That's what I'm going to do. I'm sure there must be a hot up there that does not cycle with the ignition but this Toyota is so tight I can't get to a thing.
This was pretty easy in the 4.3 models. There is a relay under the left side kick panel that controls the center console and rear cargo bed outlets. I just replaced that relay with a "chair" adapter, which happened to have contact blades in precisely the right configuration. The outlet on the dash remains ignition controlled however.
http://shop.advanceautoparts.com/p/...ack-disconnect-chair-adapter-85614/22141311-P
I just made sure to cover the "back" of the chair with some shrink wrap as it sticks out from the socket and is hot and not insulated. I wonder if the Rav 4.4 uses a similar relay, if so this would work.
Discussion Starter · #13 ·
WJBertrand: Is there a momentary cutoff when you start the car? That is what this whole exercise is about in my case as I need uninterrupted power. I did connect to an always on circuit in the fuse panel but when you start the car it cuts off and I can't have that.
1 - 13 of 13 Posts
