Time for some tech mods! Which are always my favorite! The two tech mods I installed:
1. Scangauge II
2. Owlcam 24/7 Dashcam
I ordered both from Amazon.
Techmod 1: Scangauge II
I have been using a Scangauge II for the last 7 years in my 2012 Prius V. It is a great device to give you insight into many of the hybrid power-train and vehicle systems that are not shown on the dash. Such as but not limited to:
Hybrid battery state of charge
Engine RPM
Power in AMPS being used and being generated from brake regen.
Engine Temp
Inverter Temps
Tire Pressure
Detailed Fuel Level
And many many...more especially with the X-gauge function which allows vehicle specific parameters to be viewed.
Here is a
LINK to more detailed info on what functions that the Scangauge has.
The Scangauge is very easy to install and connects via the OBD2 port for power and data collection.
I have mine installed like this. It does not block the view of the information screen or gauges.
Here is my standard set of parameters I always have up. RPM, Hybrid Battery state of charge, Amps being used and being regen, and coolant temp.
Here is one showing the fuel level.
And really cool, is the ability to show tire pressure and tire temps....Here is a picture of the tire pressures
Here is a list of X-gauge parameters specific to Toyota vehicles.
LINK
Techmod 2: Owlcam!
The Owlcam is a 24/7 Dashcam with front and rear facing cameras. It uses both wi-fi as well as 4G LTE. LTE capability is great since it can work and alert you no matter where you are.
I started using an Owlcam in my Corvette, because I was always worried when I parked it in a public parking lot something would happen to it. This camera system really gives you piece of mind as well as a visual record of any incidents that may happen while the car is driving or parked. I bought a second unit for the RAV4.
Here is some more detailed info:
LINK
It is easy to install with the multiple sized mounting "arms".
The camera is powered by the OBD2 port and the thin power cable easily tucks into the upper dash where the glass meets the dash.
I use a 2 way OBD2 splitter so I can use both the Scangauge and the Owlcam at the same time.
LINK
As a side note, I have found no issues having these devices connected to the OBD2 port. All remote functions also work great. Enjoy!
-M
