Hey all,
I have a 1998 RAV w 77k on it
Ive had a series of codes pop up lately
P0125
P0135
P0171
I have been able to correct 0125 and 0135 by replacing the upstream o2 sensor
I havent been able to correct the 0171
It cleared for about a month then reappeared
There is hesitation till it warms
Ive changed the plugs/wires, o2 sensor, cleaned the throttle body baffle assembly, pcv, checked the injectors
Researching the problem suggest it may be the MAP sensor
The location of the MAP sensor is on the drivers side fire wall, is this correct?
If so the sensor that is located there is the 89460-42010 which is the fuel tank vapor pressure sensor
My question are
1. Is this the right sensor for this location?
2. will changing this sensor to the MAP sensor fix the problem?
3. Is there anything else that might cause this issue?
FWIW I am in the US and had it looked at by a mechanic who couldnt find any problems
Thanks
Edit I also changed the fuel tank overflow tube (it was corroded)
P0125
P0135
P0171
My question are
Thanks
