Is this too much offset (Tuck In) for 245 60 17's?
I've seen numerous posts of... anything less than 38mm as optimum but not digging the ones in that fitment.
-d-
Considering the stock 18s were ET45 and it took 32mm spacers up front and 37mm in back to be flush.. these wheels you've chosen will tuck quite a bit.. but not much more than oem.
My 2009 were 45, but if yours are 35 use the offset calculator to help figure out how it'll look.
Discussion Starter #5 (Edited)
An 6-8mm wheel spacer shouldn't cause a problem should it? That would get them in the range of 38mm wheels. Thoughts? Is that taking too many threads off the lug bolts?
