I have the 2016 Rav4 XLE and it has a Micro Dust and Pollen Filter Control button.
Does this use a different filter than the A/C cabin filter under the glove box, or is that this one?
Also can you use it when using heat in the winter or does it only work with the A/C system?
Thanks :nerd
The "recirc" mode is 20% fresh air. The extra button just gives you 0% fresh air, which is why its time limited to 3 min.
Thanks :nerd
It uses the same filter, and can be used with A/C or heat.
