This is a pretty simple mod that will allow your 12 volt power outlets in the console and cargo areas to be hot even when the ignition switch is off. The power outlet below the A/C controls will not be affected--it's on a different circuit and will still be tied to the ignition.
Start by removing the panel above the hood release. If you're careful, you can use a thin blade screwdriver to pop it loose on the right hand side. Use a rag to keep from scratching the adjacent panel. Once you get that top right corner loose, you can pull the panel towards you and remove it:
Notice the 3 blue relays on the left. The relay we want is the one in the middle.
Remove the power relay by pulling it straight out. You may have to rock it back and forth a bit. To make it easier for my big hands, I removed the pink IG1 relay first.
Now that the relay is out, you can see how I soldered a jumper wire across the copper colored contacts. This completes the circuit to the power outlets regardless of whether the relay is picked up or not.
Try to solder the jumper wire as close to the relay housing as possible, so it can be re-inserted into the socket.
Others have left the relay out and inserted a jumper wire across the relay socket. That works fine but be sure to use the proper crimp connectors on the jumper. This is a handy mod if you want to use 12 volt accessories, especially in the cargo area.
