1 - 8 of 8 Posts
Mods List
Performance Test run video:
https://www.reddit.com/r/rav4club/comments/uut7fi
These vids were a few years ago. Gone are the days of my reckless/careless driving! Since I had our baby, everything changed.
Safe driving everyone! Life is precious!
Wheel Tire Car Vehicle Sky
Car Wheel Tire Sky Vehicle
Wheel Tire Car Vehicle Automotive tire
Motor vehicle Car Automotive tire Hood Light
Nickel Auto part Metal Jewellery Fashion accessory
Automotive tire Wheel Rim Automotive wheel system Road surface
Machine Auto part Metal Bicycle part Camera accessory
Camera accessory Reflex camera Font Auto part Cameras & optics
Mods:
Unichip (comes with maps in 87, 89, 91 octane tune) (No check engine light) (2ARFE scion tc2 2.5L or camry 2.5L): 2014 Toyota Camry 2.5L 2AR-FE | Unichip Automotive Performance
Weapon R Header with CEL eliminator (no Check engine Light): Weapon R Header: Scion tC 2011 - 2016 (tC2)
Throttle Body boring service (from 64mm to 68mm): Maxbore.com throttle body boring service and repair
Injen Cold air intake: Injen Cold Air Intake: Scion tC 2011 - 2016 (tC2)
Wheels - 17X7 SPARCO ASSETTO GARA BLK PAINT: https://www.tirerack.com/content/tirerack/desktop/en/homepage.html
Tires (America's Tire): General Altimax RT43 - 225 /65 R17 102H SL BSW
(Satin Black) Hood wrap/stripes: Hood Wrap Vinyl | Universal Fit ( Measure Size Needed)
Exhaust tip - Dynomax Performance 36472 (DIY painted black): Dynomax Performance 36472 Dynomax Exhaust Tips | Summit Racing
Headlights (LED)
Customized Fog lights(LED) DIY - Xprite 4" Inch 60W CREE LED Fog Lights with White Halo Ring DRL Compatible with 2007-2018 Jeep Wrangler JK Off Road : https://www.amazon.com/gp/product/B017922APE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Fog lights grommet: 4" Vinyl Round Grommethttps://www.amazon.com/gp/product/B00GJLM26Y/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&th=1
Agency Power tC2 Crank Pulley
Lowering springs: https://www.amazon.com/gp/product/B01N6PNSH4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Front wheel spacers - 2pcs 32mm (1.25 inch) 5x114.3 Hubcentric Wheel Spacers with 12x1.5 Studs for Toyota:https://www.amazon.com/gp/product/B01M0YTIFP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Back wheel spacers - 2pcs 38mm (1.5 inch) 5x114.3 Hubcentric Wheel Spacers with 12x1.5 Studs for Toyota:https://www.amazon.com/gp/product/B01LYD6IG4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
* Bought the headlights lens cover (clear) from ebay. Then DIY painted the OEM housing with black.
DIY paint headlights housing:
Headlight sealer: https://www.amazon.com/gp/product/B01N5PM29J/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
There's also the headlights with clear lens cover and already painted housing (black) in ebay before but it's not available anymore.
What kind of 0-60 times are you looking at?
Hard to see in the video, but definitely looks quicker than my 2014
0-60s high 5s and low 6s and with hard wheel spin on 1st to 2nd gear being a FWD. There's really not that much gain from a NA 2.5L 4cyl but comparing it to the stock 176 hp Rav4 with 0-60 in 8-9s - There's a big difference. (No dynos)
Throttle response. Definitely.
Strongest gain I think is in the mid 4000 rpm, 2nd gear to 3rd gear. (45mph to 80mph)
Top speed - Tried once (being an idiot "don't be like me") for the top speed and reached a 130+ mph
. (Can only achieve top speed if you do it in manual shift mode and stay in 4th gear until you reach 6500rpm) - you lose power in 5th and 6th gear.
Let me know your upgrades everyone! I did a lot of tinkering in my rav4 throughout the years. This year, I am going to have my first smog check and I am going back to stock (stock header, stock air intake, and remove the unichip) for the test and might considering remaining stock as smog test here in Cali is every other year (pain the a$* to revert tostock every test)
*Unichip doesn't alter the ECU so there's no trace that my ECU was altered. FAQ Reverting to Stock | Unichip Automotive Performance
Cloud Sky Atmosphere Daytime Road surface
Discussion Starter · #6 · (Edited)
Those are impressive numbers
I have an intake and it didn't do anything for performance. What would you say made the biggest difference?
It's definitely the Unichip that made the difference.
There's tuned map for 87, 89 and 91. 89 and 91 gives the best performance. With The unichip software installed in your laptop, you can change the ignition timing or fuel trims. You can go rich or lean. Never had a CEL or failures since installing the Unichip.
The good thing about the. Unichip is it's a plug and play and it doesn't alter the ecu.
Was skeptical before purchasing the unichip but I was all smile once I installed since 2018.
I'll probably post a video to show the throttle response. It's night and day difference from stock.
I honestly never thought twice about using a chip, I've always been told they're worthless.
Thanks for sharing and please share more!
Here's the link with Dyno results for a scion TC2 with unichip (2013 -2015 rav4 has the same engine (2ARFE) with 2011 - 2016 scion tc2 and 2arfe camrys 2.5L)
There's no splicing needed when installing the unichip - just direct plug in to the throttle body sensor, mass air flow sensor and crank position sensor.
I might have to sell my parts in the future since I'm reverting back to stock. Very Satisfied with the gains though.
MPG wise, with the tune(chip) I am getting 33.6 MPG highway compared to factory specs of 27/31MPG:
Speedometer Car Vehicle Tachometer Steering part
Unichip sample map 89 octane tune
less timing, more fuel (Lean) more agressive
more timing, less fuel (rich) less aggressive
~timing, ~fuel = base/optimal map
Font Screenshot Electronic device Multimedia Software
1 - 8 of 8 Posts
