1 - 12 of 12 Posts
pancake said:
this is probably a stupid question, but would it be possible to convert an auto to a manual?
I don't think so. But, if you insist, just go to your local salvage yard and buy a Transmission, all of its components. [from the shifter all that is attached to it until the trans axle] Remember to buy the ECU. You'll need that. :shock: It's like installing ABS to a RAV4. :( . It's all an up hill battle.
Books in. Well if you have a Honda, your in luck. Transaxle Modifications, well I still haven't looked a them. But it does have a lot of URLs to checkout parts. You never know what you can find. Here they go.
http://www.advancedclutch.com
http://www.albinsgear.com.au
http://www.anaheimgear.com
http://www.andrews-products.com
http://www.a-t-s-usa.com
http://www.brewersperformance.com
http://www.ddperformance.com
http://www.toploadertransmission.com
http://www.davidkeetoploaders.com
http://www.drivetrain.com
http://www.emcogears.comindex.htm
http://www.evansperformance.com
http://www.gear-speed.com Check this one out!!
http://www.gforcetransmissions.com
http://www.glebe.co.uk
http://www.hanlonmotorsports.com
http://www.hewland-engineering.co.uk
http://www.housemanautosport.com
http://www.jericoperformance.com
http://www.kajunjon.com
http://www.kennedyeng.com
http://www.keislerauto.com
http://www.laynemachine.com
http://www.lencoracing.com
http://www.libertysgears.com
http://www.longenterprises.com
http://www.5speeds.com
http://www.mendeolatransaxles.com
http://www.moderndriveline.com
http://www.mrtrally.com.au
http://www.novak-adapt.com
http://www.oldmanengineering.com
http://www.spoonsports.us
http://www.passonperformance.com
http://www.phantomgrip.com
http://www.phii.net
http://www.quaifeamerica.com
http://www.redlineoil.com
http://www.richmondgear.com
http://www.roadraceengineering.com
http://www.rsgear.com
http://www.taylor-race.com
http://www.teamrip.com
http://www.texracing.com
http://www.tiltonracing.com
http://www.tremec.com
http://www.umsrally.com/e_index.htm
http://www.wevo.com
http://www.wrightgearbox.com
http://www.zfdoc.com
http://www.zbag.com
Well, their you have them.
K
Yes it would be possible to convert an auto into a manual. All you need is a manual gearbox from a wreck RAV4 plus it's viscous 4WD cuppling. The rear diff will be the same for the Auto and manual.
As for the engine, you will need a flywheel from an old wreck RAV, plus the auto transmission sensor will have to be hotwired. Other sensors on the engine bay should remain intact.
K
yes, as a matter of fact.
A new clutch plate, pressure plate, clutch release bearing. The clutch hydraulic cylinder is pretty easy to install since you are going to drop the engine down to do the conversion.
Overall remark.
Screw it. Better off selling your RAV and get a manual one.
1 - 12 of 12 Posts
