If you would like your MOD and/or MAINTENANCE project listed... post it on our FORUMS in the proper category... and we will consider it for submission to this page. (If you think something already posted in our forums should be added to this page... email or PM me the location of the article!
General Information Files - Applicable for all RAV4 generations.
Genuine Toyota Motor Oil (GTMO) document - Mar. 2006
Toyota Block Heater Application Guide
Identifying Bank1/Bank2/Cylinder 1/O2 sensor locations
Toyota Battery Application Guide - Nov. 2011
Toyota Battery Installation Guide - Nov. 2011
Toyota Technician Battery Tutorial - Nov. 2011
Toyota TrueStart Battery Information - Nov. 2011
DOT 571.208 Seat/Buzzer Guidelines - (Forum Discussion)
Programming Toyota Keyless Remote Transmitters - Nov. 2007
Toyota Shock Absorber Leakage and Replacement Criteria - Sept. 2011
Toyota AWD Systems Simplified (Interactive Presentation) - Feb. 2013
Complete Information about the 2.5L 2AR-FE Engine - July 2013
4.4 (2013-)
4.4 TSBs (Technical Service Bulletins) -
4.4 MECHANICAL - Intakes, Exhaust, Tune-ups, 4x4 system, Suspension, etc.
4.4 INTERIOR - Stereos, Amps, Soundproofing, Seats, Gadgets, etc.
Audio and Interior panel disassembly and installation files
4.4 Assorted PDFs
2013 RAV4 Owner's Manual
Introduction to the 2013 RAV4: Part 1 - Part 2 - Part 3 - Part 4
2013 RAV4 Brochure (USA) - Februrary 20, 2013
2013 RAV4 Brochure (UK) - February 17, 2013
4.3 (2006-2012)
4.3 TSBs (Technical Service Bulletins) - [CLICK HERE]
4.3 INTERIOR - Stereos, Amps, Soundproofing, Seats, Gadgets, etc.
Automatic Door Locking - Installation - January 29, 2007
Auto Door Lock/Unlock Installation - December 17, 2011
Cabin Air Filter Replacement - VIDEO - June 12, 2010
Head Unit (Radio) Removal - April 3, 2007
Integrated xM Install (.96 meg pdf) - April 21, 2007
i-Pod Interface Install (Europe)701k PDF - 2006-2011
i-Pod Interface Install (USA)702k PDF - 2006-2011
Rear Cargo Area Light (door triggered) - Nov. 13, 2006
Reset Maintenance Required Light - Oct. 19, 2006
Upper Glove Box - Keep Stuff from Sliding Around - Feb. 06, 2006
How to install an auto dimming mirror with Homelink- Feb. 06, 2006
http://www.rav4world.com/forums/98-4-3-interior/67572-homelink-project-completed.html - Sept. 04, 2007
http://www.rav4world.com/forums/98-...alled-09-rav4-now-step-step-instructions.html - Sept. 17, 2009
http://rav4world.com/forums/98-4-3-interior/87138-installed-homelink-transmitter.html - Oct. 08, 2011
4.3 EXTERIOR - Tires, Wheels, Lights, Spoilers, Flares, Bars, Tow Hitches, etc.
Aerodynamics - Spoilers, Spats, Etc. - (Forum Discussion)
Bumper Protector (rear) Installation - (Forum Discussion)
Fog Light Install using OEM Wiring - May 2, 2007
Horn Improvement (Replace w/Camry Horn)
Lift/Jack Support Locations - April 13, 2007
Mudguard Installation (with flares) (64k pdf)
Mudguard Installation (without flares) (187k pdf)
Trailer Wiring Harness - VIDEO
Trailer Wire Harness (installation) 2.0M PDF
Tow Hitch Wiring Guide - May 20, 2006 (Forum Discussion)
4.3 MECHANICAL - Intakes, Exhaust, Tune-ups, 4x4 system, Suspension, etc.
4wd System Description 103kb PDF
Block Heater Installation - 2GR-FE 3.5L V6
Block Heater 2AZ-FE 2.4L I4
Brake Control System 591kb PDF (Forum Discussion)
How to Disable Traction Control and VSC - May 01, 2006
I4 (2009+) Oil Change Instructions - July 6, 2009
V6 Oil Change Instructions - August 30, 2011
Complete Overview of the 2GR-FE 3.5L V6
Complete Overview of the 2AZ-FE 2.4L I4
Complete Overview of the 2AR-FE 2.5L I4
4.3 Assorted PDFs
New RAV4 Features: 2006 - 2007 - 2008 - 2009 - 2010 - 2011 - 2012
AC Description 354kb PDF
Customize Parameters (buzzers/lights/ac/etc.) 15kb PDF
Oil Filter I4 (2AZ-FE) 185kb PDF
Oil Filter V6 (2GR-FE) 312kb PDF
Pre-Delivery Service Checklist 18kb PDF
Rear Differential Construction/Operation 259kb PDF
RS3200 (alarm) Owner's Guide 267kb PDF
Steering 1 61kb PDF / Steering 2 134kb PDF / Steering 3 65kb PDF
Tire Pressure Warning System (How it works!) 69kb PDF
Tire Pressure Warning System (Removal/Installation) 154kb PDF
Upper Console Removal (ceiling) 34kb GIF
VIN Decoder (2006) - Aug. 23, 2005
VIN Decoder (2007) - Apr. 10, 2007
VIN Decoder (2008) - Sep.. 21, 2007
VIN Decoder (2009) - Jul. 7, 2008
VIN Decoder (2010) - Aug. 28, 2009
VIN Decoder (2011) - Sep. 15, 2010
2012 RAV4 Brochure (USA) - May 14, 2012
2012 RAV4 Brochure (CAN) - May 14, 2012
2012 RAV4 Brochure (UK) - May 14, 2012
2012 RAV4 Brochure (AUS) - May 14, 2012
4.2 (2001-2005)
4.2 TSBs (Technical Service Bulletins) - [CLICK HERE]
4.2 INTERIOR - Stereos, Amps, Soundproofing, Seats, Gadgets, etc.
Head Unit (radio) Installation
Door Speaker Installation - July 3, 2001
4.2 EXTERIOR - Tires, Wheels, Lights, Spoilers, Flares, Bars, Tow Hitches, etc.
Fog Light Mod [on, regardless of dim or bright]
4.2 MECHANICAL - Intakes, Exhaust, Tune-ups, 4x4 system, Suspension, etc.
UK Rear Door Hinge Mod by Pete
2005 Oil Change - by nouse4aname
4.2 Assorted PDFs
Scheduled Maintenance Guides (US) (PDF) 2001 - 2002 - 2003 - 2004- 2005
US Sales Brochures - 2001 - 2002
Australia Sales Brochure - 2001
4.1 (1994-2000)
4.1 TSBs (Technical Service Bulletins) - [CLICK HERE]
4.1 INTERIOR - Stereos, Amps, Soundproofing, Seats, Gadgets, etc.
Radio Replacement - by InstallDr.com
4.1 EXTERIOR - Tires, Wheels, Lights, Spoilers, Flares, Bars, Tow Hitches, etc.
4.1 MECHANICAL - Intakes, Exhaust, Tune-ups, 4x4 system, Suspension, etc.
5th Gear Popping Out (DIY) - February 8, 2007
How to remove stock intake box under headlight (98-00) - March 27, 2006
Idle Air Control (IAC) Cleaning Instructions
Rear Sway Bar Installation - Courtesy of tinmanchris217
Replacing front Brake Pads - December 20, 2006
4.1 Assorted PDFs
1996 Fold-up Paper Model- Get your FREE toy here!
1998 RAV4 Cupholder Update - Convert your 1994-1997 model!
Fog Light Wiring Tips - 1996/97 Factory & Do-it-yourself PDF
Custom Ground Wires - How to Make (PDF) by Derek Nishimura
Custom Ground Wires - How to Install (PDF) by Derek Nishimura
Scheduled Maintenance Guides (US) (PDF) 1997 - 1998 - 1999 - 2000
US Sales Brochures - 1996 - 1998 - 1999 - 2000
The part number listed in the cup holder update link is no longer available at the website link listed. Will check and see if it is available elsewhere.
If you would like your MOD and/or MAINTENANCE project listed... post it on our FORUMS in the proper category... and we will consider it for submission to this page. (If you think something already posted in our forums should be added to this page... email or PM me the location of the article! 8) )
4.3 (2006-2011)
Most of the links in the 4.3 section are dead.
Can they be reloaded?
Thank you,
--Chuck--
Thank you,
--Chuck--
OK, I just finished fixing all the links on this page. I'm pretty sure I got them all, but let me know of any that may not work.
Thanks!
Thanks!
Hi! I noticed all the links that use the format
"http: //www. rav4world.com/forums/viewtopic.php?p=nnnnnnn"
on their permalink are failing. I tried both IE9 and Chrome, so I am sure it's not me. Even though I am signed on when linking, the new window that opens shows me up as a guest. I could not read a couple that interested me... :wall :)
This is a great resource, thanks for providing it!
Yes, these links were from the old system, they got broken when the forum software was switched to vBulletin. I've gone through them and fixed the ones I could find.
4.2 (2001-2005)
The list here is from 2001-2005. Where I currently live the 4.2 models are from 2000-2006. Were the models outside Europe/Japan different?
