So I'm mounting a clinometer off of a Japanese 4Runner (Surf) that I got off of eBay for a really great deal. Everything's been going fine with me modifying the plastic housing to mount on the dash somewhat decently and I was planning on tying its light source into the clock's power... But it seems the clock has four wires. Grey, blue, green, and white with a black strip. Now, the clinometer has the green and white with black stripe coming off of it. I'm not sure what the other two wires do but I see no reason why I can't still simply tie in the matching fires from the clinometer to the ones on the clock back and ignore the other two.
This guy has a page on installing them but for 4Runners and pickups:
http://www.4crawler.com/4x4/CheapTricks/Clinometer.shtml
I emailed and asked his advance and his response was:
"Not familiar with the Rav4 wiring. Sounds like you are describing the wires on the clock, it likely has constant and switched power, back light and ground wires. You might instead try the back of the lighter socket"
Obviously the clock's power is a lot more accessible than the lighter's for mounting it on the center top of the dash so I'd like to stay with that. I see no reason why Toyota would start using the exact same wire color codes for completely different things on related vehicles of the same vintage. If anyone who is familiar with wiring things on the RAV4.1 can help out, I'd be much appreciative . Pictures will definitely follow either way once I get the vinyl dyed something other than Horrid Reddish. Thanks. - Colt
