The better to scare away the little door dinging kiddies with.
:wink: Well, I ran into a bit of a problem. Finally went onto the highway the other day and my steering wheel started shaking at freeway speeds. Went back to the shop to have them check the balance on the rims. They said that they needed to install hubcentric rings. Don't know why they didn't do it in the first place. Well, after leaving and testing it out again at freeway speeds, it was still shaking at 65mph. At that point, I got tired and tried to get a second opinion from a shop that I knew had a good reputation amongst import racers. Yep, it turns out that the Kumhos while balanced on the rims were utter crap. Too many flat points and high/low points on the tires. I kinda knew that was gonna happen cause Kumho, while cheap, had somewhat of a reputation of being hard to balance and/or producing defective tires. So now, I'm cutting my loses with cheapo tires and going for Pirelli P Zeros at the reputable shop. I knew I should've spent the money to begin with at the better shop. Ah well. Oh and anyone from San Jose..avoid Wheel Works on Capitol Ave unless you want the run around like I did.
