Hello Everyone
This is my Rav4 that I’ve retrofitted for camping, originally mum’s car that ended up being passed among other family members before I’ve purchased her, She is a 06 Rav4 Base model “CV” 2.4L 2AZ-FE oil burner. 4 Speed Automatic. (Petrol, diesel wasn't available in OZ was in NZ)
"Full Service history" (did skip a service for a whole year once according to the documentation)
No name for the Rav other than Rav4 or Rav, She has been fitted with a lift kit, bigger tires and a dual battery to date (Oct 2022). Taken me 3 years for the whole refit. (Bits at a time and started with no mechanical experience)
Originally started as a bit of a joke of taking the rav4 camping in places you'd see more capable vehicles, but after a few K’s ($) in parts and a lot of alcohol as payment to myself for the labour I present the almost finish rav4 (Just waiting on AER for the rear differential locker) while not as impressive as say … in terms of pulling the motor and reinforcing the frame I present my joke car. (though that I'm not sure if I'm still joking)
In the 15 years of living in QLD I’ve only seen 3 lifted Rav4 (3rd gen) including my own.
One on the highway at Oxley towards Wacol
Another one spring lifted at Redlands Hospital (King springs?, yellow springs)
Inspired from other from this forum for their rav4 builds.
brentkwhitley
dannjolly
TEKSMRT
Rdog422
Daniel3214
Summary list of additions in no particular order. (Added after I purchased her)
- OEM Nudge bar (Apparently its an Australia only thing?) (Made in Australia Too)
- Dual battery (110AMP AGM + CTEK D250SE Plus an extra relay to jump start myself (Saved my ass a few times) (Under the boot floor)
- Spot lights
- Roof Rack (OEM from the wreckers) (Perfect colour match)
- UHF (GME, with light duty springs and antenna) (Heavy duty Stubby spring was just too heavy for the bonnet mount)
- Skid Plate (Northwoods)
- Lift kit (Northwoods)
- Rear Spring Spacer (35MM To level the Northwoods kit) (Ebay special, Polyurethane from Russia)
- 245/65/17R Falken Wildpeak AT3 Tires
- Full Suspension bushing replacement (Did this over multiples times, [never again, do it once if you value your time]) (Mostly Polyurethane such as Superpro, Nolathane and Siberia Bushings)
- Aux Transmission Cooler. (And thermostat @ a later date. Inline [Oil Cooler] after the radiator)
- Sandgrabba??? Floor mats (I know not really a mod but fuck me, it saves so much time cleaning mud and sand)
- “Engine Guard” Temp monitor, (Dual Sensor Engine and trans) (Paranoid of killing my motor by focusing on the road and not the gauges)
- Strut Bar (No particular reason other than I like the look)
- Bilstein Rear shocks
- Custom front & rear sway bars (Mako/Signature Sway bars) Front 27mm, Rear 24mm)
Story time, oldest addition to newest.
But before that the "Completed Rav" to date (Oct 2022)
Sorry for potato pics, I don't normally create a new threads on forums just normally reply to others so I didn't intent for the pics to be made public. But others inspired me so at least I can inspire others. Maybe???
Timeline of event
August 2018
Officially My Car
Changed her Trans fluid first time after this. 180KM after 12 Years (Topped and filled at 1 week intervals for 3 weeks)
June 2019
Aftermarket Auxiliary Transmission Cooler (Davies Craig 677) Installed in preparation on my first “off roading trip” to Bribie Island with the boys. Runs inline after the cooler from the Radiator. (As far as I can tell, OZ Rav4s don’t have the hockey puck fluid exchanger) Didn't have a bash plate on this trip, so I didn't air down to preserve my clearance as i was worried id hit a hidden rock and damage my oil or transmission pan. (Got bogged a lot as a result. lesson learnt)
Pic of the installed Auxiliary cooler. No thermostat was installed at this time.
Fluid flows in this order: Transmission - Radiator - Aux Cooler - Transmission
July 2019
OEM Nudge bar installed
Chose the Toyota OEM over a aftermarket due to the additional bracket that is installed from the crash bar to the nudge that is near the top (requires the whole bumper to be removed to be properly installed, verses the aftermarket which is installed/secured at the bottom only. Bonus for the OEM is the additional plate at the bottom [the part with all the oval holes])
Toyota Part: (2AZ-FE) I believe the v6 has a different mount bracket and a different part number.
PZQ29-42080
Installed only because I like the look of the nudge, I'm fully aware it does more damage in a crash, wanted the option to add accessories to it.
Pic of the rav was at a later date. Featuring the Geolandars tires installed as mentioned below
March 2020
Got All Terrain Tires, encouraged from a friend who its more outdoorsy than myself. Yokohama 225/65R17 (Stock Size) Geolandar AT G015 Passenger Tires
August 2019
Northwood Bash installed 6MM Aluminium (only option at the time)
Modified to fit the nudge bar. Best part is it happens to slide on top of the nudge.
The pick of the cut is a few years (2022) later so you can ignore the rusty washer.
Took the RAV to Fraser island shorty after (With mates) Made the whole experience pretty confidence inspiring not having to worry about the oil pans. Nice smooth layer of sand behind the rav due to the lack of clearance in some areas, pretty funny to watch the rav plough a small mount of sand into a flat path.
Saved my vehicle once when we took a unnecessary path and hit a rock. Mate in front hit the same rock and dented his radiator (didn't realise it at the time and fortunately it didn't leak. he removed his bash prior and forgot to remount it)
Only got bogged 3 times in 7 days. Not even in the usual spots such as inskip. Didn't attempt ngkala rocks in this configuration.
January 2021
Dual Battery Retrofit
Installed this as those portable battery packs to power a camping fridge wasn't cutting it. Especially when camping in an area with no sun for those portable solar panels for long periods.
Installed in the empty space under the boot floor.
Ran a line from the front battery to the back via the passenger firewall (right hand drive) and through the footwell trims. Connects to a CTEK D250SE battery charger and then the battery. Picked the ctek for the option of solar panel inputs and its ability to back charge the primary battery when the secondary is done (Also cheaper than a redarc alternative)
Installed an additional button near the driver and a starter relay (200A) to manually link the batteries together and bypass the ctek.
A gutted cargo area
Blue ground cable was moved to the right as illustrated below. Ended up connecting to a bolt holding the wheel jack carrier. Routed the positive red cable under a crossmember, Reinforced the cable with tesa tape in areas I assumed would rub. Smaller red cable is to connect the relay in the rear to a button in the front.
Almost finished setup featuring backup fire extinguisher in a hard to access place. Yes those are house circuit breakers (clipsal) used as a master switch before normal blade fuses didn't want to spend the extra $ for those waterproof 4x4 models and these are rated for 24v DC according to the spec sheet. Also a good practice is to add a fuse near each battery.
Used a 110ah agm battery, might switch to lithium in the near future for the weight savings. 600kg carrying capacity (Including driver/passengers) before gross mass
Breaking the log into smaller posts as I'll hit the 10 attachment limit.
