I took that "AE" picture of my fuse box. It's a 2008 Limited and the black wire on the left is the power cable to the autodimming mirror with compass that was installed by Toyota at the port of entry. Your 2012 Base has AZ on the fuse box?
I meant to say "HZ" which if you turn 90 degrees says "IN" which is what mine shows. I could take a picture. Although not really relevant to my post, My Donelleygentex mirror went into acc via a fusetap.
And hope you are okay with me using that picture. I was searching to see if this forum had any info as to what the letters could mean and I found your post and realized I could probably use the photo without having a took a photo of mine (though your letters were not identical to mine!)
No problem using the picture--I uploaded it here and used it in several posts.
Maybe the letters designate different fuse boxes. For example, mine is a V6 2WD, whereas maybe an I4 4WD used a different one.
Man, I thought I had an insightful explanation for it at one point, but I doubt I was considering how it differed from car to car. hm! Still wanna know what those mean.
