Hi, I have a 2020 Rav4 Hybrid XSE. My work requires quite a bit of travel so I have to carry a gun from time to time. I want to be able to secure this and would like to mount a small vehicle safe under the front passenger seat. Does anyone know are there any wires or other obstructions I need to take into consideration before drilling mounting holes in this area?
Thanks,
You're in the 4.3 section when you should post in the 4.5 section. At any rate, don't know about your 2020, but there would be no way to fit a safe under the seat of my 2010 Rav.
A portable safe small enough to fit under the seat which has a cable may do? May put it under the rear seat. There should be somewhere you can actually wrap the cable around the seat leg like mine so you don't need to drill any holes.
