If you are looking at the used wheel market then I suggest you go to this site to get your wheel specs. Then print out all the other models that matches your wheel. This way you are not limited to just looking for a RAV4 alloy wheel. Good lucky on your search.I’m basically looking for the cheapest solution. I’m in NY and the roads are heavily salted, hence the rust. The car will be 15 years old and although it’s running good and is still in good condition. I don’t want to over spend on it.
I’m going to check out the local junk yards, there are a lot of them around here.
thank you for your clarification and suggestions.
Kb
Yes they will fit. I have a 18 inch alloy wheel and that is the factory size for the Sport model. My tire size is 235 x 18 x 55.I found a set off an 06 rav4, but they are 18" alloys. Will the 18 inch fit with out issue? Bolt on?
Yes it will fit as long as the center bore is the correct size.So I found another set for my wife’s car. Will these for an 08 base model with out rubbing?? I’m not sure of the width of lug pattern.
Lug pattern 5 x 114
Rims 18 x 7.5
TPMS monitors included
TYIA
That seller is really clueless on wheel sizes. One can just read the tire size to find out that information.Sadly these didn’t work out for me. The seller thought they were 18 inch rims, but they were 16 inch. The search goes on..
