Check in the engine bay. There are a bunch of fuses and relays. Look for a plastic black cover.
The horn relay is on the driver's side junction block, under dash on left hand side. There is no air conditioning relay. There's a heater relay, your blower fan won't come on if that's not working.
hi yes thanks i downloaded that and cant make any sense of itYou can download the factory service manual (FSM). There's a link in a sticky in the General forum.
Steve, I'm afraid this isn't a DIY type of repair. You're going to need to take the thing to a good A/C technician, so he can put the gauges on it and test it properly. It may be something as simple as a bad pressure switch, or possibly a bad compressor.ok so here is where i am at at min
been told there is no relay on mine so cant do that test
again i waited till car was cold and aircon works fin for 10 to 15 min
but as soon as engine gets to running temp then aircon light starts flashing and aircon not working
any advice or people had this same issue that dont have a relay to check please advise anything else i can check
