1 - 13 of 13 Posts
In my 02 I went with the more expensive Akebono pads since I'm not going to service then again for a very long time. Most quiet pads there is. Made in Japan
Sent from my SM-G955U using Tapatalk
Do the advice and akebono pads come with new clips. Some are pictured with new clips the Advice and Ake are not.
I would pick the Advics or the Toyota branded version of it. I have never had any luck with aftermarket brake pads on any of my three Toyotas.
As for rotors I have come to really trust Centric, which I believe are also an OEM supplier for various manufacturers.
I purchased Hawk HPS pads and Centric Cryo-treated rotors. Best braking combo I have felt.
If you are changing front pads, check your rotors. Even better - get them turned even if you are only replacing pads.
get hawk brake pads
buy once, cry once...
well more than once.
soft pads that put a lot of braking force. the only drawback is that they wear out faster than normal pads and are more expensive.
All Products
1 - 13 of 13 Posts
