I used Penzoil, Liqui Moly, Idemitsu, Motul, Mobil 1. I didn't find any difference in noise level.Did anyone use Penzoil Platinum Full Synthetic 0W-16?
Good deal, cheapest I found it was at $32/5 quart bottle and I'm in the US, $30 Canadian is a great deal. I can only get it from Amazon so when I change the oil I order a new one since it could take a month or so to find it available.I might get Penzoil as they have it in Canadian Tire for 30$ Canadian on sale 😅 5QTS
Correct. The only difference between Toyota 0W-16 and Mobil 1 is the Toyota blend has slightly higher Molly Content. Per “Bob’s the Oil Guy” NOA.No, I changed with Mobil 1 several times at the dealership, no issues even when I still had my 2 year free oil change. Toyota will only change it once a year or 10,000 miles so if you want to change it every 6 months you'll have to pay. Now I just installed a Fumoto valve and change myself w/ Mobil 1 0W-16, Walmart sells it the cheapest.
ExxonMobil manufacturers Toyota engine oil and dealerships will even substitute with Mobil 1 if they're out of Toyota branded oil. Mobil 1 is also a partner of TRD.
They overfilled mine at my last oil change a week ago. I checked the oil on the spot before leaving. Yep, overfilled quite a bit. Went back and showed it to them. They said they have a machine where you put in your model and it pumps out the right amount of oil for your vehicle.Anyone else have the knuckeheads at the dealership add 5 qts of oil instead of the specified 4.8? I went in for my "free" oil change and they used 5 qts (of unlabled bulk oil) leading to an overfil on the dip stick. I called them out on it and they said they overfill because no one ever checks the oil. I know it's a little thing but the dealership is suppose to follow the manual right, that's why they charge 50% more than independant shops.
I drove home, got my gear, drained the 5 qts of unbranded mystery oil and added the correct amount of Mobil 1 0-16. That's my last 'free' oil change I'll use and probably the last time I go to the dealer. There was no one over 30 in the service department.
Slightly? 10 times bigger number.Toyota blend has slightly higher Molly Content.
The overfill seems to be a frequent occurrence. The dealer did that on myAnyone else have the knuckeheads at the dealership add 5 qts of oil instead of the specified 4.8? I went in for my "free" oil change and they used 5 qts (of unlabled bulk oil) leading to an overfil on the dip stick. I called them out on it and they said they overfill because no one ever checks the oil. I know it's a little thing but the dealership is suppose to follow the manual right, that's why they charge 50% more than independant shops.
Forgot to also mention that last time since the most recent one a week ago, the same dealership got the oil level correct(looks like their machine needs a calibration, lol), but didn't install a crush washer. Luckily the bolt held and no leaks. Going to try to drain some of the oil tomorrow. Hopefully they installed a crush washer this time. This was the last of my Toyotacare oil changes. From now on it's diy.They overfilled mine at my last oil change a week ago. I checked the oil on the spot before leaving. Yep, overfilled quite a bit. Went back and showed it to them. They said they have a machine where you put in your model and it pumps out the right amount of oil for your vehicle.
I am wondering if Canadian Toyota dealer would accept my own oil if I would bring it to them myself or example Mobil1 or something like that or they would just tell me to get lostMost people will do just as good or better job than the dealer but hope you never have an oil related failure. Good luck with your ensuing fight.
Yes, I wanted to let the M1 users down easy.Slightly? 10 times bigger number.
Unlikely if they already offer M1. However, can't hurt to ask.I am wondering if Canadian Toyota dealer would accept my own oil if I would bring it to them myself or example Mobil1 or something like that or they would just tell me to get lost![]()
Looking at the price of Toyota oil at the dealership is not as bad - I am just learning about Toyota as I am coming from German carsYes, I wanted to let the M1 users down easy.
I'm not too concerned. FWIW, long ago in another world, Ford(?) made "heavy-duty" engines by using a different dip-stick calibrated for 6qt instead of 5qt. It easily fit in the large pans of the day. Yes, I know what F.O.R.D. stands for.5 qts of oil instead of the specified 4.8?....leading to an overfil on the dip stick. ...they said they overfill because no one ever checks the oil.
