First new toyota 06 4cyl limited,couple of quick questions,What size is the drain plug and are the magnatised ones worth it and two where would the prescibed jacking points be and what would the factory specs be for torquing the lug nuts Thanks
Good question...dano said:You know i looked in the owners manuel and that only tells you where to jack it with factory jack .What if i wanted to lift up and rotate tires what would be safe Thanks
