1 - 10 of 10 Posts
Just curious. Are all the pipes of the same length, or otherwise dimensioned to consider timing/length?
Actually pictured - one intake manifold and one exhaust manifold?
ebay product?
Kirk
OK, watch for cracking at the flange, if it happens you will have to gusset the join where the pipes meet the flange.
If there is a bracket where it takes the pressure of the weight of the turbo off of the manifold pipes you should be ok.
Kirk
stainless steel is pron to crack in this kind of application,
sometimes it's too hard due the Chrome presence to a point of becoming fragile.
having to withstand a lot of heat and cool cycles, it's not elastic enough as an plane simple steel.
1 - 10 of 10 Posts
