P
:D My left headlight went bad last night... tried to search but no luck :cry:
Anybody knows how to get access and replace the bulb?
tenks!
It's in the manual if you haven't looked there yet. But if you don't have a manual, it's pretty easy. Just look at the housing behind the headlight. You should be able to pull the electrical connector out. If I remember right theres some tabs on the connector that you should pry a bit to pull the connector out. Remove the rubber insulator. Grab the bulb and rotate it counterclockwise. Pull the bulb straight out. Reverse to install new bulb making sure that you don't touch the surface of the bulb with your fingers.
P
Headlight Bulb Replacement
1) Pull off the 3 wire plug and the rubber ring seal together.
2) Unclip the left and right spring clips that hold the H4 bulb in place.
3) Carefully pull out the old bulb.
If you want to replace the H4 bulbs with better bulbs, get some Philips Vision Plus bulbs ($22 delivered for a pair from the UK).
http://www.powerbulbs.co.uk/aftrack.asp?ID=32
When replacing the new bulb, use some Bulb Grease on the 3 contacts, and be sure never to touch the glass on the bulb with your fingers. If you do, clean it with some medical alcohol pads.
This takes about 5 minutes and no tools are required.
